Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
using USB wi-fi adapter to connect wireless network
MY question is:
if I remove the wi-fi network card inside of my iMac, can I use any USB dongle to connect the wi-fi of my home network?
I want to remove wireless card cause I want to use miniPCIexpress slot for other purposes
thanks
Add a comment
1 Answer
Chosen Solution
you need one compatible with OSX.
I have this : http://www.amazon.com/gp/product/B002RCK...
for a similar problem, but not the same.
I do, or did have to use this on a older OSX based computer running 10.5..... i did have to use the little OSX airlink tool/program rather then built in airport to control it.
Not sure if this works with snow leopard or lion.
something to look into or maybe point you in the right direction, or look for more reviews etc..... i don't have latest info for wireless for mac since this worked fine for what i was doing at the time.
Score 1
Add a comment
Add your answer
joleisa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,835
