Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Weak Signal after replace LCD Display
I changed my LCD assembly, just after that my iPhone have a weak signal o lost signal (no service), think i don't replace the screws at same order. Somebody help me ..! Thanks
Score 2
Add a comment
Chosen Solution
Please refer to my earlier post here.
Accepted Answer
Included are images of correct screw length needed.
Good Luck.
Score 1
Add a comment
Most Helpful Answer
Hi, look carefully at this thread
wi-fi distance was reduced
and look at the pictures. It is common to forget that small silver piece which gives contact to the wifi. Let us know if that helps!
~asle
Score 1
Add a comment
check connector #7, place a tape on it just to make sure it's connected properly
Add a comment
There is a little metal piece "clip" next to the battery connector, Also called the pressure contact. These clip has a small pin that has to be bent in order to touch the back cover of the phone. If not you will have a "No carrier" issue.
Cheers
Erik
1 Comment:
[linked product missing or disabled: IF182-023]
by
Add a comment
try a restore ! even if is the hardest way it works every time
Add a comment
Add your answer
Georges will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 11,976
