Suspected water ingress in Camera
Is it possible to reseal a eufyCam 2C? If i take the camera inside I can dry it out but this doesn't prevent condensation from building up again.
Hi @simon57050
You may need to do more than just dry it out.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the camera's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your camera and then remove the battery as soon as possible from the camera to minimize any further damage.
Then you need to dis-assemble the rest of the device and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the camera might possibly work correctly again.
Here is a video that shows how to open it that may help.
Once you are satisfied that all is OK you could try sealing the unit up running a bead of neutral cure silicone sealant around the seam to ensure that it remains waterproof.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 29
