Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
Why is my iPhone 3GS not turning on?
Okay i have a really weird story on what happened to my two iphones. I swapped one front assembly from one iphone to another and then my iphone wont turn on? Then i swapped it back to the original and now both will not turn on. Both wont even charge or anything
2 Comments:
Wait now one charges and it vibrates when i hit the switch.
No display tho. I dont think its the lcd
by
Iv done this countless times, somethings not right
by
Add a comment
1 Answer
Use this manual to open each phone up and redo the process. This time, check carefully for cables you disconnected accidentally, or anything that differs from the pictures in the guide you should be seeing. You likely made a small mistake while replacing the assembly.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,283
