The iMac is Apple's line of all-in-one desktop computers.
8395 Questions View all
Question Closed
Intel iMac won't turn on - confirm faulty power supply
I have a 2008 intel imac (a1224) that refuses to start up after a power failure. I press the power button but no sounds, no lights, nothing. I took it apart and found that diagnostic LED #1 lights up but it seems to flicker rather than remain solid. Lights 2-4 don't light up. I followed the instructions on this page:
iMac Intel 20" EMC 2210 Power Supply Output Voltage Test
to test the power supply and found that pin 5 showed about 1v and pin 8 had 3.3v. The rest were 0v. I just wanted to confirm that this is what a faulty power supply looks like before I shell out for a replacement.
Also, does anyone have a list of eee numbers that will fit this model imac? The one out of my computer is 04X.
Add a comment
1 Answer
Chosen Solution
LED 1 indicates enough startup voltage... since it's flickering there's a problem with the power supply it probably does need to be replaced.
For the power supply see this Answer
If this Answer is helpful please remember to return and mark it Accepted.
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 3,949
