The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
29 Questions View all
Why is the heater core busted on my 1996 Cadillac Eldorado?
need directions in replacing a heater core
Score 1
Add a comment
Chosen Solution
brandon, here is what the service manual wants you to do :-):
"1. Disconnect the negative battery cable.
2. Partially drain the coolant. Refer to Cooling System Draining and Filling in Engine Cooling.
3. Remove the instrument panel compartment. Refer to Instrument Panel Storage Compartment Replacement in Instrument Panel, Gauges and Console.
4. Remove the right sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gauges and Console.
5. Remove the heater and A/C programmer. Refer to Programmer Replacement .
6. Disconnect the driver air mix actuator (2).
7. Disconnect the passenger air mix actuator (3).
8. Remove the heater core cover.
9. Remove the inlet and outlet heater hoses from the heater core.
10. Remove the heater retaining screws.
11. Remove the heater core."
Hope this helps, good luck.
Score 3
Add a comment
@oldturkey03
Hey, where did you get that service manual. The instructions refer to other parts of the book. It would be nice if you could post a link to buy it or a link to download a off for free. Thanks in advance.
-Bryan
Add a comment
Add your answer
brandon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 7
All Time: 2,188
