Released February 2015, the Samsung Galaxy A7 operates on Android OS, features a Super AMOLED screen and an octa-core processor.
light black patches after some days it covered the whole screen.
My samsung galaxy a7 fall in waer bucket but was quickly removed and dried for 2days .it was working when switched on but was having some light black patches after some days it covered the whole screen.now visibility is very dull
Any remedies to increase visibility or can the background changed to while so that WhatsApp messages can be read?
Or do I have to change the display?
Add a comment
1 Answer
Most Helpful Answer
Hi @sudhirr92646
What exact model A7 is it?
There are 3 Galaxy A7 models and they all use different screens:
Galaxy A7 (2015) sm-A700
Galaxy A7 (2016) sm-A710
Galaxy A7 (2017) sm-A720.
There may be more than just a screen problem. Check if the colour of the LDI (liquid damage indicator) is red, as this will let you know if perhaps damage to the systemboard has possibly occurred.
If it is, here's what you will have to do.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is video that shows how to replace the screen in a Galaxy A7 (2015). Search YouTube for videos if you have a different A7 model.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 1
Add a comment
Add your answer
Sudhirr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 129
