1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor
185 Questions View all
Why doesn't my new harddrive show up in diskutil?
Hello,
I installed a new HD in my mini recently after the old one failed. But I can't see it in diskutil or the installer when I boot up from DVD (I tried all tiger, leopard and snow leopard disks).
First I thought I bought a broken harddrive or there is some problem with the mini.
I managed to boot xubuntu from a livecd on the very same mini. And there I can see the HDD fine; I can format it, read write ... whatever I want to do.
I can also connect the mini in target mode to my macbook and there I can access the HDD fine too.
So I installed snow leopard on the HDD via target mode. Now when I boot up I get a stop sign from the mini.
I'm puzzled - if there would be a hardware problem, why does the disk work in ubuntu?
Thanks!
Add a comment
1 Answer
Chosen Solution
Sounds like your new drive is to fast for your machine. Try using the jumpers to slow it down to 1.5. Do a web search for the name of your drive and jumpers to find the correct ones to jump.
Score 3
Comments:
+ The jumper configuration for limiting the hard drive to 1.5GBs should be in a diagram on the hard drive's label. The jumper pins are located on the same side of the drive where the cable(s) plug into it.
by
Add a comment
Add your answer
Torben Schneider will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 965
