Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
Question Closed
Can't Format Second HDD
Added 2nd HDD (Seagate Momentus XT ST750LX003 750GB). Installation seems fine, Mini recognizes drive.
When I try to format, using Mac OS Extended (Journaled), it begins, then fails with the following error:
Disk Erase failed
Disk Erase failed with the error:
File system formatter failed.
Partition information then shows the name as diskOs2 with the Mac OS Extended as the type.
I can change the number of partitions, but it still gives the same error when I try to format one of the partitions.
Any ideas appreciated.
Add a comment
1 Answer
Chosen Solution
PARTITION
Choose disk, then in the info on the bottom under Options you want to choose GUID as the partition type (for your Intel based Mac).
If this answer was helpful please remember to return an mark it Accepted.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 893
