Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
How to identify hardware or software if Touch Bar is not functioning?
Found Touch Bar is not functioning at all (completely dark and no response) on my 2019 16" MacBook Pro, can't find TouchBarServer from activity monitor. I did try the followings:
  1. Restart the laptop, no luck.
  2. Reset PRAM and SMC, and no luck.
  3. Mac OS update, no luck.
Is there a way can confirm if this is due to hardware failure or software issue?
Any thoughts?
Thanks,
Add a comment
1 Answer
Chosen Solution
My guess you have a hardware issue. Just the same follow this guide How to fix a non-working TouchBar
6 Comments:
Than you Dan! By the way, if it is hardware issue, is it relatively easy to repair or fix?
by
@cxz - It depends! Is the display cracked, the panel driver or the touch controller?
The panel is quite hard, the driver and controller are not T bad but does require taking the main logic board out and all three parts are not cheap!
by
@danj — Hello Dan, Display is perfect, no cracks. I knew how to remove the logic board from this model. Are the driver and controller separated components and easily to be removed and replaced? Just want to see if it is worth of doing repairs. And also, is there a simple way to do screen brightness and volume adjustment easily without going to system preference panel? Thanks again.
by
@cxz - I find a good straight edge and a strong light can help in checking a crack display. Often the backside of the panel fails as that side is quite brittle. So you often won’t see the damage.
Review MacBook Pro 16" 2019 Teardown there you will see the two daughter circuits which connect to the TouchBar panel.
by
@danj - Thanks Dan.
by
Show 1 more comment
Add a comment
Add your answer
Shaun will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 288
