Screws too tight? can this be?
Hey guys. Just used the upper case replacement guide to clean and check for dust and some old coffee accident traces, all worked fine and easy, but since then my optical drive started to act like crazy.
After a while i discovered that i maybe have tighten the whole thing a bit too much. Loosing up on the down side and a bit on the sides already helped a bit, but not quite as it was before. It still has a few strange sounds and sometimes spits out the disk.
Maybe i put too much force by putting the upper case back in its place? Can it be slightly bent?
Thanks a lot for any info.
1 Comment
Hi.
Just repeated the whole procedure again. I tried to bent the upper side of the superdrive a bit upwards with a guitar pick, testing with a disk until it smoothly went in and out. It was obviously slightly bent inwards.
Now it runs good again.
It seems important not to put too much force by reassembling the upper case.
And maybe even the screws.
Thanks for the reply.
by Mavrideus
