2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Question Closed
fan cable, battry not detect, osx indicator stay at 0%, not charging,
what is that small cable next to right fan cable on the logic board? the fan power cable has four small cable. the cable i am asking has only 2 small cables.
i was cleaning my macbook pro's logic board from dust. i also put in a new and better thermal paste(arctic silver). during the process, i broke 1 of the leg of the cable next to the right fan(but not the fan power cable). i did broke the housing left arm. but the cable still seated right and secured. when i try to boot up my mac, it boot correctly but i just found out today that the battery wont charged. when i push the button on the battery it turn on about 4 dots(80%).
On the top right of the screen, if i click on the battery level it says 0% and stays on calculating charge time. i wonder is it because i broke the housing or what.
this is the actual pictures:
http://img535.imageshack.us/img535/6140/...
http://img267.imageshack.us/img267/442/i...
Close up:
http://img600.imageshack.us/img600/4063/...
http://imageshack.us/photo/my-images/42/...
my question is it the source of the problem? thx
can i solve this problem by soldering the cable arm directly to the logic board? just the right side of the cable. the left side of the cable is fine.
Add a comment
1 Answer
I believe it is the right thermal sensor. If you're capable of soldering it (soldering logic boards require special tools, skills & solder- generally not for DIYers), and can accomplish that without further damaging the board, it should work.
If this Answer is helpful please remember to return and mark it Accepted.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 451
