Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2338 or EMC 3598.
Swap logicboard and touch-ID with another MacBook same model
I have Two identical MacBook Air m1’s models. One is grey with broken screen, the other is space grey that is locked. Other than that all specs are the same, I.e. the base configuration.
I want to put the logicboard from the grey one with the busted screen into the space grey one that is locked, effectively making the space grey one not locked. Will that work considering Apple serialising and locking everything in all sort of ways.
Any help is appreciated.
Add a comment
1 Answer
As you are swapping the logic boards with there power button (TouchID) that would work but why are you gonging Dow the hardier path? I would just swap out the displays as that would be the quicker and less risky path.
What can be confusing is a virgin display (brand new) wouldn’t work correctly as the displays firmware is not installed! That’s why you need the calibration tool, a used display in this series works! So in your case the working display.
Add a comment
Add your answer
Mkkn Nkdl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 122
