How to fix my electric trunk Kia quoris 2013?!
How to fix my electric trunk Kia quoris 2013 ?!
Hi @bahaazayed
Check that the 10A Module 1 fuse located in the passenger compartment fuse box, under the dashboard on the driver’s side, behind the protective cover is OK. Here's an image showing where it is situated in the fuse box.
(click on image)
If the fuse is OK check that the trunk lock actuator and trunk open switch are both OK. Here's an image that shows how to test if they are OK or not.
(click on image)
f you're experiencing issues with the electric trunk of your Kia Quoris 2013, there are a few troubleshooting steps you can take to try and fix the problem:
If you've attempted these troubleshooting steps and the issue persists, it's recommended to have a professional mechanic or authorized Kia service center diagnose and repair the electric trunk. They will have access to specialized tools and knowledge specific to your vehicle model, which can help identify and fix the problem more accurately.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 37
2 Comments
As a diyer, did you try checking for a blown fuse? Next is searching for access to the electric solenoid release assembly in the trunk. You may have to remove panels or covers for access then visually examine for wiring damage/disconnection/corrosion on terminals. Using remote or interior trunk release button, have someone press to release as you observe and listen for actuation. Having a multimeter to measure voltage on the terminals when activating release should show 12v power to the solenoid to determine if power or solenoid failed.
by F Dryer
When you say your electric trunk isn't working, could you clarify what you mean? Does it not open or close? When you open it, does it beep?
by Kuromi
