Up to 20% off select tools
Small fully automatic coffee machines from Melitta. The Melitta Caffeo Solo makes approximately two cups of coffee at a time. Milk foam is only possible with the "Perfect Milk" variants.
Selection button not responsive
The single cup serving button is not responsive, but the 2 cup button works ok.
Is this controlled by a micro switch?
Add a comment
Most Helpful Answer
I did not do this repair until now, but I'm quite sure, there is a microswitch, which has to be replaced. Another possibility: replace the PCB. I found a used one for you at ebay.
Use this guide to open the Caffeo and have a look.
Score 2
1 Comment:
The info was useful for disassembling but there is more work to do to release the front panel. It looks like the fault will be with the pcb/ display/ switch pack.
The link to the pcb/display controller on eBay do not post to the UK.
Thanks.
by Share
Add a comment
Don't they ship to UK?
Score 2
1 Comment:
No they don’t ship to uk.
After looking at the inside of the machine after 2.5 years use, it looks well worn so I have decided to get a new one as I think there will be other problems ahead.
by Share
Add a comment
2.5 years - that's nothing! These devices live nearly forever, just like airplanes, if worn parts are replaced in time.
Another possibility: the service of Melitta itself is good and not too expensive.
Score 1
Add a comment
Add your answer
Steven Mccluskey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 24
All Time: 426
