Device will not power on after battery replacement.
I have recently replaced the battery on an iPhone 7+, everything worked as properly before I sealed the device, however after applying adhesive and sealing the phone off so there were no signs of life except for the fact that itunes was able to recognize the device being in recovery mode. I disassembled the device and still do not see anything wrong. Any advice?
Info:
You say "applied the adhesive"? Are you referring to a screen seal, as sold here: iPhone 7 Plus Display Assembly Adhesive? Or are you using a liquid electronics adhesive such as B7000? Or something else?
by Justin Castle
My apologies Justin, I was referring to a screen seal.
by Austin North
@gadgetgurus did you check your conntectors and cables?
by timtom77
