AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Questions View all
Replacing Magsafe "T" connector with an "L" connector
Hi,
I have a Magsafe 85W with a broken T connector, and I have a Magsafe 85W with an L connector but a failing power supply.
So I want to replace the broken T connector with my other L connector.
It would be ok to join both cables in the same order, the inner cable of the T power supply, with the inner cable from the L connector, and the outside cable with the outside cable from the L connector?
Thank you!
Esteban
Score 1
Add a comment
Chosen Solution
Sure. I interchange them all the time.
Score 5
1 Comment:
Thank you for answering, it's working perfect.
by
Add a comment
Like the previous answer. Connect the inner cables together and the outer cables together. I just did it and it works perfectly.
Add a comment
Add your answer
Esteban Eid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 16
All Time: 9,032
