The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
F02 error code washing
I have read recent blogs of the "fix" for the F02 error code, which was easy ready and Thank you so much! I found a my son's little sock, pen cap and change in the change trap. So, I thought GREAT, saved some $$ - that had to be problem. Put a load of laundry in and water is coming pouring out of the bottom of washer. Thoughts?.?. HELP Please!!
Score -1
Add a comment
1 Answer
Chosen Solution
pantherpride, it is possible that you have an improperly installed drain hose. Check your drain hose installation to make sure that it is properly installed. Check to see if your drain hose is stuck way down the standpipe. If the standpipe opening is taped of, it can cause water to be siphoned out of the washer during the cycle.If water is leaking out of the bottom of the washer, unplug the washer and remove the bottom front panel. Once the panel is removed, check the tub, door boot seal, the hose between the tub and the drain pump, the drain pump and the drain hose. If you need to , you can get the service manual from here and there are more images on on this question. Hope this helps, good luck.
Score 2
1 Comment:
Will do!! Thank you so much for the quick response!! Going to continue this mission after work tomorrow, def. will check back in on the results. I was confused as it was not leaking before I cleared out all the debre from hte trap and I didn't mess with any of the hoses. I will walk through your steps above and let you know. Thank you again! Much appreciated!!
by
Add a comment
Add your answer
pantherpride will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,628
