Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Questions View all
upgrading my mid 2017 iMac, 256 blade ssd rot a 1 TB blade ssd
If I can't Upgrade to macOS 10.13 or later, prior to Aura Pro X2 installation on my iMac 2017, 27", EMC3070, is there a work around the upgrade?
Update (05/14/23)
Dan,
I understand That I can upgrade my OS. My current problem Is that I was not the adminstrator and I was locked out by a soft ware controlling program. I have all ready disassembled my I Mac, so any upgrades to the OS, will have to be after I upgrade the hardware. Is this possible?
Thank you Dan for your help.
Add a comment
1 Answer
I think you got things confused, your system can support newer macOSs. The issue is two fold, the newer OSs use a different file system (APFS) Vs what you currently have (HFS+). So the systems firmware first needs to be updated so a drive which holds your OS can boot up under it. But there is a second issue here as Apple also setup a unified driver for storage. So now you need to newer driver for the OWC PCIe/NVMe SSD drive within the newer firmware and OS.
So to upgrade your storage you need to upgrade your OS your system is running. Then in that process both the systems firmware an the OS on drive will be upgraded.
So that solves the firmware issue, but we still haven’t installed the OWC drive so how can I get the OS installed after putting the drive in?
The easiest way is to create a bootable OS installer using a USB thumb drive. Using the OS installer you can prep the USB drive and then after swapping out the drives you can then boot-up under the external drive which you have copied the OS installer to running it directly from the USB drive
Update (05/14/23)
Well, the alters things a bit. Depending on the management software you may not be able to overcome it. The rub here is some alter the firmware.
So you need to create an external bootable drive. Grab the OS installer from here How to download macOS and follow this guide to setup the external drive Create a bootable installer for macOS
Then using this external Thumb drive boot up under it to see if you can reformat and install the OS on what you have now. If that works then upgrading to a larger SSD is possible.
Add a comment
Add your answer
Larry Paterson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 28
