Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
What is the best size for the blade SSD?
Before I close everything up, just wanted to know if a 500 tb pci e card is overkill if I am also replacing the data hd with an ssd? I have a 128 gb blade I can put in its place instead. Any thoughts??
Add a comment
1 Answer
Chosen Solution
A 512GB blade SSD is what I would go with even if you install a SATA based drive be it a HDD or SSD.
The reasoning is this drive will be your boot drive hosting your OS and apps as well as be used for Virtual RAM space, Caching & depending on the apps you use scratch space.
Score 1
1 Comment:
Thanks so much!!
by
Add a comment
Add your answer
Krista Couch will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 118
