Connected to Wi-Fi but no internet access
I connect to any Wi-Fi or hotspot, but I’m not connecting to internet !?
It shows that I am connected to the Wi-Fi, but I cannot do anything on the net.
How can I fix this ?
What is the URL you are trying to reach and the Web browser you are using?
I don’t think your system is the issue here, I’m thinking your internet router setting is messed up. See if turning off the router, give it a good two minutes so the logic board flushes its settings and see if that fixes things.
I have open windows on safari that I use daily. Now I cannot access any. I have done nothing different.
@minimoo - What is your exact system?
I think you need to see if a wired connection works. Depending on the given system you may have an Ethernet connection (RJ45) to just connect the cable otherwise you’ll need a Thunderbolt adapter. See if that works.
It’s a MacBook Air, I can’t plug it in unless I go and buy a special adapter.
@minimoo - OK what year and size?
From 2017, size 13
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 50
