Repair guides, support, and troubleshooting information for the 2022 13-inch MacBook Air, featuring Apple's M2 SoC. Released on July 15th, 2022 and identified by model number A2681.
42 Questions View all
How to properly disassemble the keyboard area and clean it?
I want to clean some dust off the keyboards on my Macbook M2 Air. I have cleaned the top of the keycaps but some dust might have gotten beneath in and between the small gaps. Is it possible to safely disable the motherboard and the keyboard area so that I can dust the keys?
Add a comment
1 Answer
The keyboard is riveted to the uppercase and getting to it from the inside is quite difficult. Since you have such a new system I would leave things alone. Dust is mostly not the worry, liquids are! Clearly don’t use your system on the beach of eat food which is crumbly as this type of debris can also cause harm.
If you haven’t I would sign up for AppleCare+ That will give you a bit more protection if you are likely planning to go into a war zone or just have messy kids😎
Only use a lightly dampen clean towel with mild counter cleaner on the shell and keyboard surfaces, and for the screen straight water (distilled being best) on a lightly dampen clean towel and if the dirt is stubborn, add a little White Vinegar.
Add a comment
Add your answer
Tatasky HD will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 25
All Time: 230
