Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
R button only being able to be pressed down a little
So the R button on my 3ds xl works but it can only be half pressed down compared to the L button which can be full pressed is there a solution to this?
Add a comment
1 Answer
Hey! Ogur Bear,
  • One possible solution for this issue is to open up your 3DS XL and check the R button mechanism for any damage or debris that might be preventing it from being fully pressed down. If you are not comfortable with opening up your device, you can take it to a professional repair service to have it fixed.
  • Another option is to try cleaning the button using compressed air or a cotton swab and rubbing alcohol. This might help remove any dirt or debris that might be causing the issue.
  • If none of these solutions work, it might be necessary to replace the R button altogether. Replacement parts can often be found online or through a repair service.
Add a comment
Add your answer
Ogur Bear will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 77
