iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Questions View all
How to eject stuck cd?
The cd has a paper sticker on it (is from ADS Tech!!!). I have tried the terminal, Toast, rebooting with left side of trackpad down, the works...
I read that a guy had inserted a flat head screwdriver tip in the cd slot and managed to 'catch' the cd. If I knew the internal 'design' of the cd-rom slot, I might try it.
Any suggestions?
Thank you
PHX
Score -1
Add a comment
Chosen Solution
To remove he disk without destroying it or the drive, your best bet is to open the machine and open the disk drive. Here's how to get to it: iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement Opening the actual drive usually7 only involves four to six small screws to remove the top and gain access.
Score 3
Add a comment
Here's a blog post I made answering the very same question on ejecting a "stuck CD" from my iMac. Hope this helps! If you have any questions, let me know! http://bit.ly/GVZg50
Best,
Davey
Add a comment
Add your answer
PHX will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,993
