Third generation Surface Pro tablet, released June 20, 2014.
Won't turn on - how can I get data?
Hello. Yesterday my surface pro 3 stopped wouldn't turning on. In case it was the battery/power, I tried a couple of different chargers - but both show the pro is charging, and still the screen doesn't turn on. I tried the hard reset by pressing and holding the power button - after about 20 seconds the charger light blinks momentarily before going back to being solid, as if to show the pro is restarting, but still no turning on.
I recently bought a new computer as the pro was getting old, and my concern is not the device, but the data. I last backed up the pro about a month ago. There is data on there I need access to. Is there a way of getting it?
Thank you very much.
Add a comment
1 Answer
Most Helpful Answer
Hi @emmie3298
Here's one way which is not that easy but it's doable. Depends how much possible damage to the laptop you're prepared to accept.
Here's the ifixit Microsoft Surface Pro 3 SSD Replacement guide that will help.
Once you have gained access to the SSD (that's the hard part) and removed it, you should be able to then insert it into a PC that has a spare M.2 port so that essentially it becomes a storage drive in that PC and retrieve the data that way from the SSD.
Score 1
1 Comment:
Thank you very much!
by
Add a comment
Add your answer
Emmie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 389
