Ps4 slim 2 second blue light of death (BLOD)
My ps4 died in a storm (maybe lightning strike). The hdmi chip had a hole so i removed that and got a new power supply; now ps4 is on 2 second BLOD. I havent replaced the hdmi ic as there is no white light.
All DJ diodes (shown in red circle, 3 in the bottom, 1 on the top (no photo) ) have blown and so is the 22 ohm resistor near hdmi port. I removed all of them.
The 5v sot23-5 LDO is giving out 9V and maybe that took out these diodes, the 2.2V LDO on the left is fine. I removed the 5V LDO, and noticed the enable pin pad (from pin 35 of syscon?!?!) is showing 2 ohms to ground. I lifted syscon chip but still the pad is ground.I have checked almost all capacitors for any short. I need help with the enable pad as syscon is not responsible for the ground. I havent injected power as it is a last resort. Also i don't have a thermal camera, so i could potentially cause further damage.
Edit: the trace runs to pin 2 of this ic also, shown below. I removed this ic still the pad has only 2 ohms to ground.
4 Comments
PS4 BLOD refers to an indefinitely pulsing blue light. Turning back off in 2 seconds is different. I wish I could be of more help, but it sounds like you have a better idea of what's going on.
by Dan Sayers
@dushku no problem dan. I am also not a tech guy all these info i got from YouTube and using a multimeter.
But there is one more thing maybe you can help me with. I am trying so hard thinking this board is a 9.00 or below firmware. Is there any way to check the firmware from the hard drive? I don't want to remove the nor chip unnecessarily
by h. p
Since there is no suggestion i went ahead and tried injecting voltage. It is not a dead short. So at 1v i get only 0.4A draw. At 1.8V i get 0.6A draw. At 2.5V i get 0.8A draw. None of which is enough to cause a heat spot i guess. I don't want to bump the voltage any further :(
by h. p
Through voltage injection i found the issue to be the apu power controller ic ir35211a. Replaced it with same model and the ps4 is back to life.
by h. p
