Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2338 or EMC 3598.
How to remove keys off of a MacBook air
i want to make sure before removing any keys by just pulling them off that there isn't any adhesive or anything i could damage by just pulling the keys off of the key board
the reason that im removing the keys is because of a large amount sugar got under the keys on the left side of the keyboard
thanks in advance
Add a comment
1 Answer
Most Helpful Answer
Why are you removing the KeyCaps?
Score 1
6 Comments:
I'm removing them to clean out a large amount of sugar that was spilled on the keyboard and got under the keys :C
by
@timtomissus Without being able to give a proper method to remove the keycaps efficiently, I can say that they are only held on by tiny plastic clips on butterfly hinges. These clips break very often, so be gentle.
by
@cashewclay can you still put the key back on if the clip breaks?
by
@timtomissus Each key cap has two clips and two tabs, as pictured quite well here: https://www.laptop-parts.com/blog/MacBoo...
Check out where the clips are before prying, just so you know exactly where to pry and minimize the chance of breaking clips.
Edit: my partner just informed me that you may have scissor switches, not butterfly keys.
by
@cashewclay would it be the same protocol if the mac had scissor switches?
by
Show 1 more comment
Add a comment
Add your answer
timtom77 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 354
