Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
What other parts are required to replace the touchbar?
Hello , recently I'm having issue that my MacBook Pro 16" 2019 keeps shutting down or restarts by it's own. I have another problem too where the Touchbar keeps flickering and blank buy it's responding. I went to the apple store they said it's not the logic board problem. It's the touchbar , where the top case need to be replaced. Can I know what other parts are required to replace the Touchbar ? Thank you.
Add a comment
1 Answer
Well… Apple loves making things hard! Sadly, it’s not a simple. The TouchBar is glued down to the uppercase quite well. I’ve used solvents and heat taking a few hours to get it off in the older 2016/17 models when I was able to get my hands on the part.
Frankly, the 16” part is about $150 USD getting a uppercase I think is the better direction today. First your battery is getting close to four years, your keycaps are likely a bit worn as well. A used uppercase can be had for $300 USD a new one from Apple is about a hundred more with a fresh battery.
But, I’m not sure you need a new TouchBar. Often the driver logic which is located on the cable is the problem.
Add a comment
Add your answer
Saabiresh Letchumanan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 118
