After fan replacement, battery no longer being detected and charging
I replaced the fan that was causing the laptop CPU to go to 90-100c causing a loud fan and that was fixed successfully. However, now the battery is no longer detected. It has an x symbol before typing in the password and whilst the laptop is on there is no battery symbol in the menu bar. Plugging out the charger makes the laptop immediately shut off.
If I don't have the charger plugged in and the computer is switched off, the 'battery needs charging symbol appears' and that's the only time the battery is acknowledged as being present.
If I plug out the battery data/daughter cable from the logic board and try to turn on the PC that symbol no longer appears and there is no power in the system so it must be detecting the battery to some extent. I have also tried doing SMC and PRAM resets multiple times. Is there any other suggestions? Thanks.
-- Update
CoconutBattery shows the following information:
The cable connection:
