Can I get my charging port replaced?
I pulled out my charging port by accident when I put the wrong charger in and there aren't many places to get it replaced. Where can I get a new charging port.
Abdullaah, you can buy the replacement port itself on most of the online merchants such as AliExpress, Amazon and eBay.
In order to replace it yourself, you'll need to use the 3DS Motherboard Replacement guide to remove the motherboard, then unsolder the old port and solder in the new one.
Nintendo 3DS Motherboard Replacement - iFixit Repair Guide
If you don't feel confident enough in your soldering and repair skills to do the repair, you'll need to locate a repair shop that can do the job for you. For a competent technician this should be a fairly straight-forward repair and shouldn't cost too much.
Just for reference, there's another post on the same subject that has more information for you.
SOLVED: How easy would it be to repair the 3DS charge port? - Nintendo 3DS - iFixit
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 333
