A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
PS4 won't accept any disc's even after new drive installed
I bought a new optics drive from ifixit and after taking it completely apart and replacing the drive it still won't accept any disc's.
My old disc drive was failing and I had to tap the top of the ps4 while inserting cds, so I think it was the drive failing. But its still happening after the repair. I can manually insert the disc but it won't even recognize when I'm attempting to put a disc in.
Add a comment
1 Answer
Most Helpful Answer
Tell me if I'm wrong, but what I'm reading is that you go to stick the disc in and the console continues to sit there like you're not. If so, you likely have a blown fuse ON THE MOTHERBOARD. All swapping the drive would do is put presumably clean gears in place of the ones that have debris in them that strained the intake motor in the first place. Generally speaking.
Here's where you find Slim BD fuses on the motherboard.
Here is where you can source replacement 0402 BD fuses.
Score 1
1 Comment:
Thank you Dan for the response.
Yes when ever I try to put a disc in it does not attempt to automatically pull the disc in.
I will look into the potential fuse issue and let you know if it is the issue!
by
Add a comment
Add your answer
Joshua will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 115
