Small fully automatic coffee machines from Melitta. The Melitta Caffeo Solo makes approximately two cups of coffee at a time. Milk foam is only possible with the "Perfect Milk" variants.
Size of the grind
Hi,
I opened the Caffeo Solo for a cleanup and closed it back. Now when the motor grind, the size of the coffee grind is top big and the infusion is not happening. I tried to change the size of the grind, nothing changed.
Thks
Add a comment
1 Answer
Chosen Solution
Did you open the grinder? Follow this guide, open it and adjust it. This is a good opportunity for a replacement of the grindstones.
Score 1
5 Comments:
Thks for the quick answer ! I'll try next weekend and let you know.
by
I followed the tutorial but nothing changed. The size of the grind is still too big. I didn't see where to adjust so it might be that.
by
I don't know why, but this part does not appear in the english translation:
Jura Grindstone Replacement
by
If you want to watch the grinder, when opened, use an empty toilet roll.
by
I finally had time to unmount it and managed to fix it. The issue was that I did not screw properly the black ring (size selector) to the grinder. Thank you very much for your help.
by
Add a comment
Add your answer
Romain will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 35
All Time: 908
