Why does my pc turn on but my monitor says no signal?
I just built my pc when I turned my new pc build on the Rgb and the fans turned on and everything look like it was on. Except I noticed that my monitor said no signal I have the usb with the windows plugged into the back of the motherboard. I have built a pc before that works perfectly fine and this has never happened before. I tried to get another usb with windows on it and it still did not work there was still no signal on the monitor. I even tried to unplug and reconnecting all the wires form the power supply I compared the cords to my good working pc. that did not work either. I tried to even reinstall my graphics card and still there was no signal. I reconnected the pc to another monitor which did not work it still said no signal. I have no clue what to do if you have any tips on what to try I'm all ears.
1 Comment
I just remembered that I did turn on the pc without the usb with windows on it. I put the usb in after it was on i don’t know if that could cause the no signal. If it does cause the no signal what do you think I should do next.
by JustAFlower
