Google's third-generation Pixel-branded smartphone, and their first "notched" phone. Comes with a 6.3" QHD+ OLED display and 64 or 128 GB of storage. Available in Nearly White, Just Black, or Not Pink.
How hard is it to restore the water resistance?
I have a Pixel 3 XL a family member broke the screen on, so I bought a donor phone to get the screen and got the phone going and it worked out well (outside of ripping the matched camera on one side, and fingerprint reader but since I was working with a donor device heh), didn't even have to recalibrate the finger sensor because I reset it and never touched it until I could confirm it works. They didn't want it back, so free phone (well, outside of needing to buy a parts phone).
Is it possible to restore the water resistance reliably on these, or should I consign myself to no water resistance and just seal it well enough to close (but be serviceable) once I replace the battery? The battery I put in was bent in (pulled from the donor) removal a little, but it worked for testing.
Score 1
Add a comment
Chosen Solution
Once you open it that’s it. All you can do is to reseat it with tape or glue, then keep it dry. Glue if applied correctly will give a better seal.
Score 2
2 Comments:
It was compromised from being cracked on both the rear and front glass anyway most likely.
Yeah that original back glass DID NOT survive - I had to replace it.
by
I gave up trying. I'll reseal it for back adhesion with Tesa tape or something once I can buy a battery that isn't a low-grade tester that's high risk.
Would I like it back? Yes, but I also do not trust the liquid resistance beyond oops my phone got wet in the rain or a liquid splash anyway. I can compensate by taking precautions.
by
Add a comment
Most Helpful Answer
Even with an original seal, there really isn't a 100% waterproof phone, if you search Pixel 3xl back housing seal you will find some with the same shape and size as the original, i woud recommend using a proper seal made for your phone model because doing it by hand with double sided tape will often leave gaps in the corners where dust and liquid can come through.
Honestly just closing it well enough with tape or glue you have should be fine if you are the one using it, but like i said, phone are not waterproof.
Score 2
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 565
