Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2338 or EMC 3598.
Screen cracks when opening
Hello. I changed the screen of a macbook and I realized that when I open and close the screen quickly (normaly, like if it's the first time you open your mac), there are no problems. But if I move it gently to reposition the screen higher or lower and therefore go more slowly when I move it, it makes a little creak when I start to move it. I hope I explained myself clearly enough. Any explanations/solutions? Thanks.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi
It might be worth cleaning the hinges with isopropyl alcohol from the inside as there could be debris caught in them
Here’s the guide for getting the display off
MacBook Air 13" Late 2020 Screen Replacement
I would stay away from lubricants as they could remove the tension/stiffness of the hinges
Also if you go ahead with the isopropyl alcohol make sure to use it with a soft cloth in small amounts as it can get behind the display if you aren’t careful which can cause watermarks on the display behind the glass
Hopefully this helps
Any questions please ask
Score 1
Add a comment
Add your answer
Thibaut will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 207
