no touch screen after water damage
um my screen was cracked and it got in the toilet and it works but when i try to slide to open the screen doesnt do anything it doesnt pick up the touches waht would i need toreplace?
daniel, the first thing that I would do, is to clean my iPod. Use this as ageneral guide. Replace your battery as well as your digitizer and reevaluate. At this time it sounds like a broken digitizer. If you do not clean your iPod, you might run into corrosion issues at a later time, so I recommend that you clean it. The guides are available at iPod Touch Hope this helps, good luck.
You may not have to replace anything, follow this guide here Electronics Water Damage
+ Link in old turkeys answer, to take it apart
If that doesn't work i would try to replace the digitizer, but keep in mind that the logic board might actually be bad.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 250
