In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
78 Questions View all
What tools are required to replace the serpentine belt?
Toyota Corolla 2008
2 Comments
The 19mm nut to relieve the tension is just above the tension wheel. Very hard to see. I went to an auto parts store and asked to look at the tension bracket to see where it was located. Helped a lot.
by
easy way to replace serpentine belt on a 1999 dodge caravan 3.8 engine
by
Add a comment
Chosen Solution
You will need a breaker bar with a 19mm socket. Turn the drive belt tensioner clockwise (toward the radiator) to relieve tension on the belt, and then remove the belt. Then return the tensioner to the unloaded position.
Score 3
Add a comment
Hi ,I need to Bye the large Hexsogon spanner that goes on tensioner so I can get the se serpentine belt of my freelander1 deise l 2006. 2liter. Thanks .Ray.
2 Comments:
Hi Rob i have not got a answer from you from my last question ,,please could you send it has
by
Raymond you do see that this Q & A is 6 years old? Maybe you should ask your own question.
by
Add a comment
Add your answer
Rob will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 6,667
