Speakerphone mic stops transmitting when other person talks
Replaced the port twice now. If the 11 Pro Max is on speakerphone and they are talking, if the other person begins talking at all they will cease being able to hear them until they stop talking. Have yet to find a solution to this issue.
2 Comments
Hi Tyler,
By 'port', you're referring the the lightning port assembly containing the lower microphone, right?
The 11 Pro Max has three microphones total; one at the bottom on the lightning port flex cable, one on the rear below the right hand camera, and one in the same slot used by the earpiece speaker.
The documentation I saw says that earpiece microphone is used for Siri; I wonder if it's also used for speakerphone calls. If that's the case and the problem, then replacing the lightning port microphone wouldn't help.
Just a thought; no idea if it's worth anything or not.
P.S., another article mentions that multiple microphones may be in use simultaneously for audio pickup *and noise cancellation*. Maybe that's a clue?
Does Siri work on your phone?
by Jerry Wheeler
Siri works fine on the phone.
by Tyler Humphress
