Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
How to remove logic board residue on components
How do you remove the residue that is stuck on the logic board that covers the capacitors and other components on the logic board? I have tried using isopropyl alcohol and a tooth brush but the residue is quite hard. Are there any other chemicals or techniques i can use to make this easier?
2 Comments
Why do you need to remove it?
by
one of the capacitors needs replacing
by
Add a comment
Most Helpful Answer
You mean the black epoxy?
Apple use that stuff for a reason, those things are impossible to dissolve using alcohol and toothbrush, you'll need something like a phone BGA heater and a scalpel.
For example this video.
https://www.youtube.com/watch?v=7KPovvMP...
Score 3
Add a comment
It's called underfill. Hot air station and a blade or sharp tweezers to scrape it off should do it. About 150 to 180 degrees. Go easy so you don't damage anything.
Score 1
Add a comment
Add your answer
Morgoth will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 104
