4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Boot Loop On Plug-in, Button Fixes Do Not Work
My phone will instantly boot-loop on connection to power, white apple logo.
Will restart every 10 seconds.
Power + Home button holds do not work
Volume Up/Down buttons do not work.
Tried all buttons, the 'pressing onscreen trick' etc.
Nothing seems to work.
Of course, there is no connection visible on computer.
There is no response to any button holds whatsoever, the apple logo still loops every ten seconds.
Any body got a fix?
Add a comment
1 Answer
Most Helpful Answer
Hi
When its not turning on and it’s boot looping that usually means time for a new battery
Here’s a guide for replacing it!
iPhone SE Battery Replacement
Here’s a USA link for a Battery
iPhone SE (1st Gen) Battery
Here’s a EU link for a battery
https://eustore.ifixit.com/products/ipho...
Here’s a UK link for a battery
https://store.ifixit.co.uk/products/ipho...
If you are outside the stores I have listed please let me know and I can get you the correct link
Hopefully this helps
Any questions please ask
Replace a 1624 mAh battery compatible with a 1st generation iPhone SE. 3.82 Volts (V), 6.21 Watt Hours (Wh). This replacement does not require soldering. Image
Product
$29.99
Score 1
2 Comments:
It could be from water damage too, but most likely a battery issue for sure.
by
@cooltool
You are correct about the water damage,if they find any they can remove it while they are replacing it:-)
by
Add a comment
Add your answer
Royal Toad Club will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 29
All Time: 108
