Repair guides, support, and troubleshooting information for the 2022 13-inch MacBook Air, featuring Apple's M2 SoC. Released on July 15th, 2022 and identified by model number A2681.
42 Questions View all
Which bit do I use to remove back?
Looking for the correct bit to open my Air M2. P5 seems loose when I try to use it.
Score 2
Add a comment
Chosen Solution
Pentalobe 1.2 5 point bit. iPhone is 0.8 and MacBook is 1.2
Score 1
Add a comment
Most Helpful Answer
Hi
I believe it is a p5 that is used
If a p5 doesn’t feel tight enough try a p6
If it’s too big try a p4
Hopefully this helps
Any questions please ask
Score 6
2 Comments:
P5 is correct. Ordered a new P5 bit and it worked great. Also purchased the magnetic project mat and highly recommend it!
by
@frankg0
I find that anything magnetic is handy:-)
by
Add a comment
A Penalope 5 screw bit probubally because apple uses the P5 bit on all MacBook pros post 2012, and airs post 2018. I do with they would change it.
Add a comment
Add your answer
frankg0 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 539
