Apple's March 2019 refresh of its iPad Air tablet, sporting an A12 Bionic processor and a 10.5" screen.
39 Questions View all
Why can I sometimes not type correctly or touch the bottom of screen?
This started happening after I cracked the top left corner of the iPad.
Sometimes, but not always, when I type, it doesn’t work right.
Example:
I tried typing “example text”
I got “eaple. tet”
Whenever this happens, I can also not interact with the bottom inch and a half of the screen.
Add a comment
1 Answer
Most Helpful Answer
It sounds quite likely that you've damaged some of the circuitry that controls the touch screen function, i.e., the digitizer.
Unfortunately, on your model of iPad it's not possible for the average person to replace just the digitizer glass, as it is fused to the LCD display, so the only option is to replace the entire LCD / digitizer assembly.
There are several sources you can buy a replacement screen from, including right here on iFixit.
iPad Air 3 Screen - iFixit Store
If you're feeling adventurous, there's a DIY guide that will step you through the entire process of replacing the screen yourself.
iPad Air 3 Screen Replacement - iFixit Repair Guide
Good luck, and let us know how it goes!
iPad Air 3 Screen Image
Product
iPad Air 3 Screen
$199.99
Score 2
Add a comment
Add your answer
Ldangerous1 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 35
