Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
471 Questions View all
Screen backlight not working - Logic board working on other screen
It started with screen flickering then it went black. Shining a light through the apple logo, I found that the screen is working fine. The logic board was tested onto another screen and it worked fine, similarly another working logic board on my screen gave the same dead backlight. It cannot be the WLED driver nor the fuse issue since the logic board is working fine.
Now I can not find a clear fix for this, can anyone guide in the right direction.
Thanks
Add a comment
1 Answer
Most Helpful Answer
Your process makes it clear the issue is within the display assembly and/or the display cable its self.
I would have just used a DVM to measure the backlight power on the logic board. But you process also works!
So you'll need to inspect the display cable contacts for damage it needs to look like this
If that looks OK, you will need to inspect the cable its self for damage and may need measure the continuity between to pins across the cable contacts once you've removed the cable fully from the display following this guide MacBook Pro 13" Retina Display Mid 2014 Display Assembly Replacement Once the display is off slide the black clutch cover to gain access to the display cable connection
The connector is just like the logic board, also look for corrosion damage across the soldered pins as well often I see the connector its self damaged. People over did the cleaning of the screen so cleaner often dripped down damaging the connector and shorting out the solder joints.
And lastly, here's the needed replacement cable: 13" MacBook Pro Hinge Left - eDP Cable, Apple P/N 661-02360
If the cable is OK then you have a deeper issue within the display assembly, I find its time to just replace the part MacBook Pro 13" Retina (Late 2013-Mid 2014) Display Assembly
MacBook Pro 13" Retina (Late 2013-Mid 2014) Display Assembly Image
Product
$599.99
Score 1
Add a comment
Add your answer
Bas ma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 85
