Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
USB rear ports not working fine: any advice?
Hi everyone, and thanks in advance.
This is what's happening with my iMac: the rear ports aren't readig any storage devices (pen-drives, Hard Disks, SD cards), but are working fine with my Apple keyboard and a Genius mouse.
I've been reading several posts in this site, and came to the conclusion that it must be a hardware problem. This are my questions:
- Is there a way to connect storage devices to the mac, not using firewire? (I've tryed plugging them to the keyboard, but that doesn't work)
- Is there any fix i can do? (As an electronic technician, i feel confident playing with electronic components)
- Is there a way to connect usb devices via firewire?
As a photographer, my work is suffering due to the lack of connection between my Mac and my devices, son any help is welcome!
Thanks a lot,
Agustín from Argentina (that's why my english isn't that good)
New information:
While performing the tests included in the Apple Service Diagnostic DVD i run into this in the Hardware Profile, does this mean a thing to anyone? (i'm a bit lost here):
USB Port
type: USB 2.0
speed: 480
uhci-id: 0x5d100000
ehci-id: 0xfd500000
port-number: <obsolete>
is-connected: TRUE
USB Port
type: USB 2.0
speed: 480
uhci-id: 0x3d100000
ehci-id: 0xfd300000
is-connected: FALSE
USB Port
type: USB 2.0
speed: 480
uhci-id: 0x1d100000
ehci-id: 0xfd100000
is-connected: FALSE
More information:
Recently I re-installed my OS, but the problem is still here, nothing changed. Anyone still thinks this may be a software related problem? Any advice could help!
Score -1
Add a comment
1 Answer
Chosen Solution
It sounds like you may not have enough voltage/current available at those outlets for what you want to hookup. I would try an inexpensive powered hub and see if that cleared my problem. I am including a link for the one I use but there are many different hubs available. Check your local computer or electronics store. Good luck.
http://eshop.macsales.com/item/Belkin/F5...
Score 3
1 Comment:
Thanks for your interest. For i while i thought that the problem was related to current, and tried what you told me. I plugged an external powered hard drive, that comes with a hub, but that didn't work (neither the HD nor the usb ports on it).
by
Add a comment
Add your answer
Agustin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 5,034
