Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
MacBook won't power on
Two months ago my son spilled water on the table, which went under my MacBook. My MacBook immediatley shut down and after drying out would not come back on. A few days ago i took it apart and cleaned the logic board with alcohol and it magically powered on. The battery is apparently a loss, though. But after a few minutes of running fine off the adapter, it shut down on me. After a few minutes I was able to turn it back on, and then after a bit the same thing happened again. And I have not been able to get it going since. My only thought is that maybe I busted the fans in the process of cleaning, and it overheated, but why am I unable to get it going now? Please help... it's terribly painful having to live without my MacBook.
Score 1
3 Comments
Good Question. If you look under "water damage" or "Liquid Spill" on the search tab, you'll find dozens of similar threads that you may find useful.
by
I found those, thats how i got it to power on after a good cleaning. but now i'm in a new bind. i found on entry about disconnecting the pram battery, so now i'm sitting here looking dumbly at the bottom of my logic board... its not there!?
by
nevermind...
by
Add a comment
1 Answer
Chosen Solution
This link should help You spot the PRAM battery:
MacBook Core 2 Duo PRAM Battery Replacement
If you have the same machine that I have, then the PRAM is located by the right speaker. (Early 2009)
MacBook Core 2 Duo PRAM Battery (Santa Rosa/Penryn) Replacement
Score 2
1 Comment:
Why are you looking at the PRAM battery?
by
Add a comment
Add your answer
you and me will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,471
