There are so many things we could do if we only knew how. This area aims to catalog most specialized skills necessary to perform certain kinds of repairs.
How can I easily remove the bits from a 26-bit kit?
If you're anything like me, your fingers aren't needle-nosed pliers. I struggled to remove the tightly-packed bits until I wrapped a rubber band around it and then easily pulled it out. Now whenever I open the kit up, I make sure to have a rubber band nearby so I can quickly and easily get to the bit I need.
Score 1
2 Comments
Asked and answered myself. Mainly here in hopes someone else might benefit from the little tip.
by
aaronmiller, it's really not a repair related question ;-) but most certainly a great idea. I think you should take a couple of pictures and create a guide to have it posted on ifixit. http://www.ifixit.com/Guide/new I think that would be very helpful and a neat little guide to have.
Split your original question. Create one true question, and post your tip as an answer. You can even accept your own answer....:-)
by
Add a comment
Chosen Solution
Thanks for the advice oldturkey03 :D
Here's that: iFixit 26 Bit Driver Kit Technique for Removing Bits
Score 1
1 Comment:
Thanks Jamy, I tried this...handy when you don't have a rubber band around, but with a rubber band, it's even easier.
by
Add a comment
I always put the handle over the bit I want to remove, pull outwards and then upwards, remove the bit from the handle, turn it around, put it back in, and presto :)
Add a comment
Add your answer
aaronmiller will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 41
All Time: 1,805
