A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
CE-34335-8 error tried multiple hdds
Greetings,
I was playing on my ps4 the other day and it turned off. I tried to turn it back on via the power button and it wouldn't. I found that the only way I can turn it on is by putting a disc in. When I do, it gives me error CE-34355-8. I have tried putting in multiple hdds, I have tried to read the original hdd on a PC (which I can just fine), I have downloaded the system OS off Sony website and have installed it on hdd while in ps4 with no change, and I have tried EVERY option in safe mode with no change. What can I try next?
Score 1
10 Comments:
Did it overheat?
by
It didn't seem like it did. It just shut off after normal gameplay.
by
When I turn it on now, (by putting a disc in it) there is no telltale hdd click and the power button doesn't beep. When I press the power button for the 1 sec that it prompts me to, the display turns off but the light is still white. Pressing it again makes no beep and the display resumes with the error message.
by
That usually happens when something overheats.
by
Ok, so let's assume that the system did overheat. What is my next step?
by
Show 5 more comments
Add a comment
1 Answer
Same issue facing with my console also. Please some share the fix/solution
Add a comment
Add your answer
domwebhost will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 268
