Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
82 Questions View all
MB 2017 won't turn on - how to diagnose before moving to logic board?
This 2017 MacBook Retina 12 inch is dead. Different chargers and cables don't make a difference. Resetting SMC with the left ctrl + left option + left shift + power for 10 seconds doesn't work. Holding down the power button for 10 seconds doesn't work.
I even gently lifted the logic board from the internal battery connector, held it in place with plastic spludgers, plugged the MacBook into a charging brick, and tried the key combinations above.
What else can I do before testing the logic board...which I haven't found any guides to do at the moment.
Can I test the USB-C port with a multimeter to check for connectivity?
Any advice that helps me diagnose this would be great!
Edit: I've attached a photo of the board.
Score 5
Add a comment
Most Helpful Answer
@fixwiki try this first and see what you can determine
Minimum Configuration
Putting the computer in a minimum configuration helps determine which part may be malfunctioning by reintroducing parts one at a time until the problem recurs. This procedure is useful when troubleshooting symptoms such as:
No power
Will not start up
Kernel panic
To troubleshoot the MacBook using the minimum configuration, remove or disconnect all parts except:
Logic board
I/O board and flex cable assembly
Audio board
Audio board flex cable
Speaker/antenna module (Early 2015 and 2016 only)
Power
5W power adapter (Do not use a higher wattage for minimum configuration.)
USB-C cable
Reinstall or reconnect remaining parts one at time until the issue is replicated.
I'd be checking the I/O board first since that would be the entry point for power.
The LIO is what I was referring to
Update 04/17/2022
this is F3500 and it's a fuse on the PPVBUS_LIO. See if you have power and /or continuity on it. If you do not then you know the issue originates on your LIO board. You do need a closer, clearer picture of your logic board to identify things . Also, consider checking the connector from the LIO on your logic board.
Score 4
14 Comments:
@oldturkey03 This is very helpful information. To know that if I connect the computer to its charger via USB-C, that the board should accept the electricity, which would enable the small light to illuminate when the gold button is depressed.
I've never once been able to get the small LED to light up. Does this indicate that electricity never gets to the Logic Board?
by
@fixwiki sure looks like it. If the LED does not come on you do not get power to the board.
by
@oldturkey03 So I could check for continuity on the USB-C port. Is there anything else I can check? You mentioned the I/O board.
by
@fixwiki yes you could. One of the things to check would be if you are you getting power from the LIO to the board?
by
@oldturkey03 Alright, so.... I'll need a multimeter to check , yes? I have 2-probe voltage tester that can go as low as 32V DC. 😁
by
Show 9 more comments
Add a comment
I have been very successful on this problem by just attaching a new battery. If it works, then I install the battery. most of the time I do not get the low battery icon on the screen before doing this.
Score 1
1 Comment:
is posible to charge batery of MiniBook 2017 Retina using a HUB 4 with regular USB enter and mini exit USB 2 or 3 only to recharge the batery ? I find a new cable (chinese ) but don't work.
by
Add a comment
If you want indepth help with board level issues, check out Louis Rossman's website that deals with it in more depth: https://repair.wiki/w/MacBook#12%22_Reti...)
Add a comment
Add your answer
FixWiki will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 959
