Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Stuck in boot loop
I’ve seen many different posts but none seem to have the information I need.
I replaced my iPhone 6 screen, when replacing it I disconnected the battery as I’ve been informed it can cause issues if you don’t when doing a screen replacement? I connected it back up after putting the screen together. Everything is connected fine and put back together, but now the phone is stuck in a boot loop.
Would anyone be able to help me fix the issue please?
2 Comments:
Have you tried disconnecting and reconnecting the battery?
by
Yes it’s still doing the same thing. It does it a few times then just stays on a blank screen but is still on. @andrewsawesome
by
Add a comment
1 Answer
Try disconnecting the proximity sensor flex. If that still doesn’t work you can try putting the device into recovery mode and restoring the software.
Add a comment
Add your answer
Teejay C will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 109
