mmm… This is not a new battery! It’s been sitting on a shelf since 2015?? Or is this your original battery??
Sadly, batteries wear out just sitting on a shelf or even inside of a system which is always plugged in to power.
So is the information here from the wrong battery or is SMC messed up. Let’s carefully disconnect the battery and with nothing plugged in press and hold the power button for a good 15 secs to fully discharge the logic board. Now carefully plug in the MagSafe leaving the battery disconnected. Your system should start wait till you get to your desktop and anything that’s auto loaded. Once everything has finished shut down your system and now reconnect the battery. Now this time restart your system, let it run for a good 5 minutes with the MagSafe connected and then take a fresh snapshot posted it here for us to see. Let’s see if things changed.
4 Comments
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by Dan
Not looking for a bot or to feed an app
by Ryan Buckner
No bot here ;-} And you don't need to buy the app the free use version is all you need for us to get a better idea what's happing.
jcdkjpvopvsic Oops! The robot in me has spoken!
by Dan
ok I've added the image
by Ryan Buckner
